Problem with simple Lofts
milos_necakovmilos_necakov Member Posts: 3
edited November 2018 in Using Onshape
I am new to Onshape, but I have used loft successfully few times until now.
I discovered that without reasons clear to me a simple loft between two circles on parallel planes will twist.
For example, if i draw circle on top plane and two circles to new offset  parallel plane, and try to apply loft between circles, it should give me straight simple lofts, right?
It does, but only on some, and not always. Is it a bug?
Here is my test on three parallel planes trying to apply simple loft between circles. As you can see some of them get narrow or even cross between two circles.
Can anyone tell me why please?
Thanks in advance!!
https://cad.onshape.com/documents/c6636d318623ab69f895d9d1/w/4b061956849c1e085282c3fe/e/a3486ab41499c41e7f5cbbdc
