Cannot Edit Imported Public Files
So in my very first project with OnShape I need a NEMA17 stepper. I go to the OnShape public warehouse and find a bazillion NEMA17 files, nearly all of which appear to be someone's copy of a 3D printer project. I choose one and select "Make a Copy" so I can edit it. (I need to change the shaft length.) I get quite a few tabs at the bottom, one of which is the NEMA17 drawing. I open it. Under Default Geometry there is "Import1", and under that, nothing. No features or anything just a blank section. So what do I have to do to unlock editing of this imported part?
The thing that those 2 chain ends attach to isn't another gear, it is the cords for the slats in a set of blinds. I have no real gear ratio to match in my case - I just need push-pull movement (actually I guess it is pull-pull) with a sprocket diameter that matches the motor torque to the resistance of the slat cords.
