Part Studio - Parts List to Indicate Revisioned Parts
Hi folks.
When working in a PartStudio I would like to be able to see at a glance which parts I've released and at which Revision.
Something like this perhaps:-
Possibly with a filter to shout about any parts that have not been released.
Cheers,
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015 image
    @owen_sparks We do this already when you are lookin at the released version.  Give that a try.  The workspace is not a place to show released parts as they can be modified.
    I can understand both sides to this issue. On one hand, the version of a document you see in the workspace is uncontrolled and therefore can't be guaranteed to be the same as the released version. On the other hand, I do think it would be good to know that "parts A and B have been released and I don't want to touch them as I work on Part C".
    As an alternative, what about showing most recent release status in search results? Maybe along-side the part numbers (and other properties) in search results? *hint-hint*
