Drawings from stl files
_Ðave_
Member, Developers Posts: 712 ✭✭✭✭
An Issue that I've been trying to find a solution for and hoping that Onshape will provide a solution is that after I perform one operation in my cam software I can verify and create an stl file of that operation from the initial stock.
This operation may not be finish as per the drawing or original solid model. What I would like to do at this point is create a process drawing of the stl with dimensions for that operation. Therefore my question is that is this something that others would be interested in and will the upcoming drawings in Onshape be capable of dimensioning stl files.
Thanks
Dave
Thanks
Dave
1
Optionslougallo Member, Moderator, Onshape Employees, Developers Posts: 2,002@Dave_Petit Currently we do not have a way to bring in STL as a tetrahedral model yet. That would be required for the upcoming drawings package. I am interested to hear the interest level of this.
Lou Gallo / PD/UX - Support - Community / Onshape, Inc.7
Mike.
Thanks
Dave
However, mechanical CAD software and most CAD formats (like STEP) use precise representations. A circle is a circle and a circular cutout (hole) is perfectly round. You can easily go from a precise format to an imprecise format but not the other way. Converting from STL to STEP is generally not possible (except in some special cases).
Spaceclaim and others have done a good job at bringing both precise and "faceted" formats together so that you can do some things like dimensions. I expect folks like Onshape and others are thinking about this too. I'd kind of like it too given the 3D printing I'm doing.
Box Edit in Rhino5 (and equivalent commands in FormZ and Modo for example) let you select an object and resize the xyz size and location just by typing in the values. This is extremely useful.
On going from STL to STEP, I should have been more clear. You are not going to get CAD friendly BREPs like Kevin Quigley pointed out.
