Loft Question
peter_paton
Member Posts: 43 ✭✭
OK, Total newbie to any CAD software, trying to work out how to loft between two profiles - called "Upper Scraper" in public documents.
I can get a loft to happen between the faces, but always with a twist effect. I have had no success trying to add guides (I used construction lines) but could not tie them to the profiles - if I changed the view the lines remain on a different plane to the profiles.
I have watched several tutorials but can't get my head around this so any help will be appreciated!
Pete
Pete
mthiesmeyer
Onshape Employees Posts: 115
Hi Peter,
Welcome to Onshape! Please take a quick look at this. Searching for a document by name can sometimes yield hundreds of results, so you'll almost always get a quicker response if you post the link to your document which in this case is here.
I took a stab at what I think you were looking for, you can access it here. I added a guide curve from each vertex to it's partner. Please note that you can't use construction lines as guides, which is probably the issue you were running into.
Best,
Mike
5 -
NeilCooke
Moderator, Onshape Employees Posts: 5,933
@peter_paton - if you are just trying to angle the end, edit your sketch and draw a traingle of the area you want to remove, then extrude/remove.
Senior Director, Technical Services, EMEA5
Best,
Mike
Many thanks for the advice. both on the question and posting guidelines.
I was using construction lines after watching a tutorial, I will need to revisit as I have obviously misunderstood! I will investigate guide curves now....
What you produced in a few minutes is exactly what I want to achieve - I only spent 2.5 hours trying and failed miserably!
Peter
Happy to help
If you do find an out-of-date tutorial, or one that conveys incorrect information, please let us know so that we can correct it for the future!
Best,
Mike
Another couple of hours down and still cant get it to do what you did! I can't work out the guides thing and the tutorials I have found refer to guides previously drawn in so not much help there!
For what I want to do today I could have drawn it with a pencil in a fraction of the time but that is not the point. I will keep working through the basic tutorials, I am probably jumping a number of steps trying to learn by drawing parts.
I double checked the tutorial I referred to, they used construction lines for another purpose so it was my interpretation that was incorrect, not the tutorial. My frustration is that they all refer to using guide lines but so far I can't see how to create them.
Cheers,
Peter
I need to angle the tip of the blade as per the construction line. Now that it is has been extruded the trim tool doesn't appear to work. Can you point me in the right direction?
Thanks in advance!
Peter
https://cad.onshape.com/documents/f84c1928e7cf1cab2de987c7/w/81606af875a4dd4194c3a937/e/7e213a6f47f21ca6c363a3b1
