Error in parameter type for addInstance
eric_ma454
Member Posts: 14 ✭
Hi all,
I am currently trying to instantiate multiple copies of a part studio on an array of points. I currently have:
elbowTest::import
elbowTest::import
const instantiator = newInstantiator(id + "myId");
addInstance(instantiator, elbowTest::build);
However, I am getting an error stating "Call addInstance(Instantiator (box), function) does not match addInstance(..., PartStudioData)," even though the SLD states addInstance can have PartStudioData type. If anyone has any insight to the reason for this error, that would be very helpful.
Bonus Q: If I have an array of points, and I would like to instantiate elbowTest on all of those points, how would I do that?
Best,
Eric Ma
AguaClara AIDE
Best,
Eric Ma
AguaClara AIDE
You'll get more help if you publish a link to your public document. Please see https://forum.onshape.com/discussion/9107/forum-post-checklist
So I imagine you want code something like this:
const points = evaluateQuery(selectedPoints); for (var i = 0; i < size(points); i++) { addInstance(instantiator, elbowTest::build, { "transform" : transform(points[i]) }); }Let me know if you have further questions!
– Kevin
Thank you for your reply. I used the transform argument used in your example, but multiple errors formed, involving:
@evMateConnectorCoordSystem: MATECONNECTOR_QUERY_CSYS_FAILED
Typecheck canBeTransform failed (value.linear is Matrix)
throw EXTRUDE_NO_SELECTED_REGION
@opPattern: Map does not contain field 'linear'
I am confused how to fix this, as well as the nature of most of the errors.
The share button on my document is grayed out, and the document doesn't say it is public, so I'm not sure if this link works:
https://cad.onshape.com/documents/740e6a14f9b0e5df6b16a58a/w/ce74bd2e6b57ecc8bb2a6914/e/cc8ee7787055eb6be4328154
