New Custom Feature - Arrows
NeilCooke
Moderator, Onshape Employees Posts: 5,392
This new custom feature creates arrows that can be used to explain how parts are assembled / disassembled, direction of travel, or how a product should be operated. You can create them in the same Part Studio as your parts or you can use in-context editing (the preferred method), then insert them into your assembly or drawing. Each arrow can have it's own colour or they can be shown wireframe. You can also use thicken to add an arrow to your solid model if you wish. Enjoy!
14
If you give a mouse a cookie...
Forget this CAD stuff, we may have to pivot into cookie production! Sounds very lucrative
On a more serious note, though, this sort of stuff is on our radar, and any notes you have about what could make features like this more functional are highly appreciated around here!
Well, Onshape does give your browser 13 cookies every time you open it up (I only counted ones from onshape.com and cad.onshape.com)
The browser may end up getting sick
However, it doesn't give it any glasses of milk
How did you do the white model with red arrows?
Thanks
Onshape needs to provide a method to align sketches and surfaces to parts when they are added to a drawing. CAD is all about precision and speed. It is neither precise or speedy to manually drag around an inserted sketch or feature and try to get it to align to a part view. Fix that and this feature will be perfect.
it flips Up/Down direction, but not rotation CW-CCW
https://cad.onshape.com/documents/e89fe92cc27465bb6eb0e421/w/4aab9e8adcde659b25215a2f/e/4b3386a3913ed02d2809b9c8
Also, straight arrows cannot be offset off the axis. Say I have a shaft that slides so I want an arrow to show that movement. I use the shaft cylindrical surface to set the axis. The arrow is completely inside the shaft. If you kept the diameter dimension used for the other types, that could be used to offset the arrow from the center by ½ the diameter, allowing the arrow to be outside the shaft.
