Sheet Metal with a laser cut though a vertex / bend
Trying to put a laser cut on a flat right where a bend will be.
We need this relief to not stretch the edges of the cut-out. After it is formed we will weld it closed.
Here is what it looks like the WRONG way, just for illustration purpose. I'm trying to do this on the flat but Onshape does not seem to let me do it unless its from edge to edge and that not acceptable.
It will be a 0.015 laser pass to cut though it.
Any suggestions?
That was my original thought but I keep getting an error, it will not let me.
I select the surface, create a sketch, draw the rectangle and extrude. :-(
Please file a support issue - this is likely to be specific to your geometry, we'll have to investigate it.
I was not the one who fixed this for you, but I suspect that what happened is that your Part Studio was "held back". This means that during our upgrade process from one version to the next, our automated system identified that using the newest code would change your geometry in some way, and decided to keep your Part Studio using the old code instead of the new code. This is great for making sure your geometry doesn't change, but means that your Part Studio does not have all the latest bug fixes. So, when you submit a support ticket, we can identify that it was held back, try manually upgrading to the latest version, while making sure that any geometry change that occurs is very slight and insignificant.
Hope this helps explain what happened in a little more detail! Feel free to ask any question!
Is there a way to tell?
This a project I've been working on for a year and been pulling my hair out on some things that I see done in instructions and webinars that don't seem to respond the way they should or how I think they should.
Could have saved hours if not days!
I hate change, get off my lawn! LOL
There's not a great way to tell from the user side, and cases like this should be pretty rare, but they do happen. Don't be afraid to have an itchy trigger finger on the "Contact Support" button! Especially if something seems off, and especially especially if you find yourself pulling your hair out! Were are here to help and happy to help
