Improvements to Onshape - December 4th, 2018
cody_armstrong
Moderator, Onshape Employees, Developers, csevp Posts: 221
It's December already and while we may be nearing the end of the year, we are not slowing down! This update includes some features that have been very highly requested. Let's dive in.
You will now see better behavior when hovering over or selecting cells in a table in Onshape Drawings.
CAD IMPROVEMENTS
FEATURE LIST FOLDERS
You can now create folders in the Feature list.INSERT DISPLAY STATES INTO ONSHAPE DRAWINGS
You can now insert assembly display states into Onshape Drawings.MATE CONNECTOR IMPROVEMENTS
Mate connector and offset value visibility has been improved with this update. This improvement makes it easier to understand the mate connector orientation and offset while creating or editing a mate.IMPROVED USER INTERFACE FOR IMPORTED FILES
The user interface for imported file tabs has been improved with this update.IMPROVED TABLE BEHAVIOR IN ONSHAPE DRAWINGS
RHINO 6 IMPORT SUPPORT
You can now import rhino files created using Rhino 6.ENTERPRISE FEATURES
ALLOW GUEST USERS TO BE GIVEN GLOBAL PERMISSIONS
Administrators of an Enterprise in Onshape can now add Guest users to Global permissions (except for the "Company administrator" permission). This is useful if you want to allow Guest users to create or approve release candidates, or manage other permissions.Please take a moment to try out these new features and improvements and leave your comments below. For a detailed list of all the changes in this update, please see the changelog.
7
I especially like the implementation of the feature tree folders. I can see some issue with the 'delete' & 'unpack' option of the folder getting confused and someone accidentally deleting many features. I think you should have to select all the features in the folder to delete them to ensure that the wrong selection isn't chosen. Also, the difference between the words may be confusing for non-native English speakers leading to extra confusion.
Beyond that concern, many of us have been waiting for feature tree folders!
We wish every company would be like Onshape.
All of these Improvements are great.
Thank you for Display states in drawings
can't wait to start using all these and especially feature folders (next up assembly folders right?)
Didn't mind the original mate connector, but this in definitely a huge improvement, I'll take it!
Thanks for the mate improvement as well, that's something I encountered but didn't realize could be improved. As always - one step ahead.
Display states in drawings, another great addition to the line up. Thanks!
Loving folders btw, now I know what config these suppressed mates are for
Too bad we can't nest folders (not so important in FS as it will be in ASM afaict)
We appreciate the input about the naming here! Rest assured that if a user accidentally selects the wrong option, the undo button will work as expected, and all work will be preserved.
This is also very useful, thanks!
The folders look good, but I do like the idea of a single folder suppress and folder selection for features and configurations.
Looking forward to trying the MC improvements.
Drawing views with display states will come handy.
Also, a big thanks for the '---' removal, haven't tried it yet but hopefully, now I'll be able to have multiple properties per cell on a title block and be able to mix and match properties.
Did this get changed in this update?
PS: I really like the feature tree folders
Still waiting for better alignment features in drawing mode. But well done!
@mbartlett21 you can change the name of a feature in the feature list and you can also set the name of the feature you are creating in the title of their form
This has been possible since sometime in beta.
Effendi H.
For me naming is consistent since also tab folders have 'unpack' and we have undo & history, so no work can get lost.
I like the idea of using folder to select, especially with configurations.
Display states in drawings is huge, no more making copies of assy for drawings.
Mate connector improvement is something that is so obvious, one would think it has always been there
In Finland we actually decided to have national holiday tomorrow to really test these updates (and celebrate 101 years of independence).
This would be in the case of, for example, somewhere where I imported an external part, inserted the translated part into several assemblies, but then need to update the initial part. Currently the new geometry goes into a new translated part studio and all the assembly references need to be updated and re-mated.
Of course, the answer to this may well be "that's infeasible, because a geometry-matching heuristic cannot be made good enough."
