Improvements to Onshape - December 4th, 2018
cody_armstrong
cody_armstrong Posts: 228 image
edited December 2018 in New in Onshape
It's December already and while we may be nearing the end of the year, we are not slowing down! This update includes some features that have been very highly requested. Let's dive in.
CAD IMPROVEMENTS
FEATURE LIST FOLDERS
You can now create folders in the Feature list.
https://onshape.wistia.com/medias/em3bfmvn57
INSERT DISPLAY STATES INTO ONSHAPE DRAWINGS
You can now insert assembly display states into Onshape Drawings.
https://onshape.wistia.com/medias/qqxp6ikpp6
MATE CONNECTOR IMPROVEMENTS
Mate connector and offset value visibility has been improved with this update. This improvement makes it easier to understand the mate connector orientation and offset while creating or editing a mate.
https://onshape.wistia.com/medias/dg36e7b5l2
IMPROVED USER INTERFACE FOR IMPORTED FILES
The user interface for imported file tabs has been improved with this update.
https://onshape.wistia.com/medias/665dirqe9d
IMPROVED TABLE BEHAVIOR IN ONSHAPE DRAWINGS
You will now see better behavior when hovering over or selecting cells in a table in Onshape Drawings.
RHINO 6 IMPORT SUPPORT
You can now import rhino files created using Rhino 6.
ENTERPRISE FEATURES
ALLOW GUEST USERS TO BE GIVEN GLOBAL PERMISSIONS
Administrators of an Enterprise in Onshape can now add Guest users to Global permissions (except for the "Company administrator" permission). This is useful if you want to allow Guest users to create or approve release candidates, or manage other permissions.
«1
  • owen_sparks
    owen_sparks Posts: 2,660 PRO
    Fantastic, thanks folks :+1:
  • Awesome update!
    I especially like the implementation of the feature tree folders. I can see some issue with the 'delete' & 'unpack' option of the folder getting confused and someone accidentally deleting many features. I think you should have to select all the features in the folder to delete them to ensure that the wrong selection isn't chosen. Also, the difference between the words may be confusing for non-native English speakers leading to extra confusion.
    Beyond that concern, many of us have been waiting for feature tree folders!
  • mahir
    mahir Posts: 1,324 ✭✭✭✭✭
    Awesome update!
    I was thinking the same thing. I like having both options, but they could be named better. Maybe "Delete Folder & Contents" and "Dissolve Folder" or "Unpack Folder Contents". Nice enhancements, though.
  • john_mcclary
    john_mcclary Posts: 4,095 PRO
    Wow, Christmas came early!
    All of these Improvements are great.
    Thank you for Display states in drawings :) Now I have a reason to use them :)
    can't wait to start using all these and especially feature folders (next up assembly folders right?)
    Didn't mind the original mate connector, but this in definitely a huge improvement, I'll take it!
  • Andrew_Enslow_3DS
    Andrew_Enslow_3DS Posts: 40 ✭✭✭
    Stoked about those feature folders!
    Thanks for the mate improvement as well, that's something I encountered but didn't realize could be improved. As always - one step ahead.
    Display states in drawings, another great addition to the line up. Thanks!
  • owen_sparks
    Ok, first "can you just".  Love the new mate connector info, it's hugely useful when creating a mate, but less so afterwards, as you have to find which mate we're after and show it.  Perhaps from a long list of possible mates.
    I'd like to propose that the "J" key behavior be extended.
    Currently it toggles between:-
    show no mates / show all mates
    I'd like three states:-
    show no mates / show all mates / show all mates and their offset and limit info
    I think this implementation would be intuitive and would lead users to discover the new mode without even seeing a training video.
    Cheers,
  • brian_brady
    brian_brady Posts: 505 EDU
    Regarding feature folders: can we place related features together in a folder and then use the folder to create a feature pattern? In other words, can we treat the folder of features as a single feature to create other features?
  • john_mcclary
    @brian_brady I see where you are heading with this. Would be an interesting thing to experiment with.
    Loving folders btw, now I know what config these suppressed mates are for :)
    Too bad we can't nest folders (not so important in FS as it will be in ASM afaict)
  • @michael_mcclain @mahir
    We appreciate the input about the naming here! Rest assured that if a user accidentally selects the wrong option, the undo button will work as expected, and all work will be preserved.
  • Nice update! Thanks for improving tables in drawings!
    This is also very useful, thanks!
    1. Improved hide ‘---’ from Drawing title blocks while exporting to PDF and printing
  • brucebartlett
    brucebartlett Posts: 2,148 PRO
    Great updates, Thankyou!!!
    The folders look good, but I do like the idea of a single folder suppress and folder selection for features and configurations.
    Looking forward to trying the MC improvements.
    Drawing views with display states will come handy.
    Also, a big thanks for the '---' removal, haven't tried it yet but hopefully, now I'll be able to have multiple properties per cell on a title block and be able to mix and match properties.
  • Great improvements. Thanks! Display states is great news!
  • MBartlett21
    MBartlett21 Posts: 2,064 ✭✭✭✭✭
    I just realised I can now rename default features. :)
    Did this get changed in this update?
    PS: I really like the feature tree folders :smiley:
  • brian_jordan
    brian_jordan Posts: 144 ✭✭✭
    The improved user interface for imported files is a nice improvement for this humble modeler for 3D printing purposes.
  • Great update!  Thanks Onshape!
    Still waiting for better alignment features in drawing mode.  But well done!
  • emagdalenaC2i
    emagdalenaC2i Posts: 867 ✭✭✭✭✭
    Great improvements!!
    @mbartlett21 you can change the name of a feature in the feature list and you can also set the name of the feature you are creating in the title of their form
    Un saludo,
  • I just realised I can now rename default features. :)
    Hi mbartlett21,
    This has been possible since sometime in beta.
    Jake Ramsley
  • MBartlett21
    Ok, I didn't know.
  • Effendi_H
    Effendi_H Posts: 19 ✭✭
    Awesome feature!
    Thanks,
    Effendi H.
  • 3dcad
    3dcad Posts: 2,482 PRO
    Great stuff and some good points how to make further improvements.
    For me naming is consistent since also tab folders have 'unpack' and we have undo & history, so no work can get lost.
    I like the idea of using folder to select, especially with configurations.
    Display states in drawings is huge, no more making copies of assy for drawings.
    Mate connector improvement is something that is so obvious, one would think it has always been there =)
    In Finland we actually decided to have national holiday tomorrow to really test these updates (and celebrate 101 years of independence).
  • MBartlett21
    Is there any way to get feature folders with the API?
  • emagdalenaC2i
    @mbartlett21 I think not yet
    Un saludo,
  • lemon1324
    lemon1324 Posts: 230 EDU
    If you update an imported file, would it be possible to update the existing translated Part Studio instead of making a new one?
    This would be in the case of, for example, somewhere where I imported an external part, inserted the translated part into several assemblies, but then need to update the initial part. Currently the new geometry goes into a new translated part studio and all the assembly references need to be updated and re-mated.
    Of course, the answer to this may well be "that's infeasible, because a geometry-matching heuristic cannot be made good enough."
    Arul Suresh
  • konstantin_shiriazdanov
    konstantin_shiriazdanov Posts: 1,221 ✭✭✭✭✭
    If to speak about assemblies geometry itself doesn't play a significant role in OS, all you may need - to repair several unique mate connectors in each assembly, where the part is used.
  • The Feature List folders are awesome, cleans up my long lists of features! just need folders in assemblies. The display states in drawings are great as well, will have many uses for this. The tables have come a long way, love this new update, much easier to work with now! great update.
  • owen_sparks
     I'd love to be able to suppress an entire folder using the configuration manager
    This.  Configs are great but adding and removing things to them can be tedious.  I've had fingers crossed for using configs to suppress an entire folder of features ever since they were announced.   Just dragging a feature into a folder to have it in a configuration would be awesome.
    Cheers,
  • emagdalenaC2i
    Un saludo,
