Thicken in certain direction
2»
  • MBartlett21
    MBartlett21 Member, OS Professional, Developers Posts: 2,064 ✭✭✭✭✭
    You need to select the face you want to replace with in the replace face box, not the face box.
    The face box is the face to extend or trim.
  • billy2
    billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,194 PRO
    @mbartlett21
    Disclaimer-I'm really bad at naming things ie... billy2
    opExtendSheetBody: Sheets
    opEdgeChange:         Edges
    I thought sheets should be surfaces, but that's too confusing. The fact the edges extends & trims means those names are out, same for sheets. You really should launch these through Neil Cooke. they're really good. Put your name in them & contact info as a comment.
  • MBartlett21
    @billy2
    Do you like the way the opEdgeChange UI populates?
  • MBartlett21
    @billy2
    I have now named the features as follows:
    opExtendSheetBody:    Extend Surface
    opEdgeChange:            Change Edge
    opCreateOutline:          Project Body
