Thicken in certain direction
2»
    You need to select the face you want to replace with in the replace face box, not the face box.
    The face box is the face to extend or trim.
    IR for AS/NZS 1100
    @mbartlett21
    Disclaimer-I'm really bad at naming things ie... billy2
    opExtendSheetBody: Sheets
    opEdgeChange:         Edges
    I thought sheets should be surfaces, but that's too confusing. The fact the edges extends & trims means those names are out, same for sheets. You really should launch these through Neil Cooke. they're really good. Put your name in them & contact info as a comment.
    @billy2
    Do you like the way the opEdgeChange UI populates?
    IR for AS/NZS 1100
    @billy2
    I have now named the features as follows:
    opExtendSheetBody:    Extend Surface
    opEdgeChange:            Change Edge
    opCreateOutline:          Project Body
    IR for AS/NZS 1100
Howdy, Stranger!
