Thicken in certain direction
2»
  • MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 1,953 EDU
    You need to select the face you want to replace with in the replace face box, not the face box.
    The face box is the face to extend or trim.
    MB - I make FeatureScripts: View FeatureScripts
  • billy2billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 1,585 PRO
    @mbartlett21
    Disclaimer-I'm really bad at naming things ie... billy2
    opExtendSheetBody: Sheets
    opEdgeChange:         Edges
    I thought sheets should be surfaces, but that's too confusing. The fact the edges extends & trims means those names are out, same for sheets. You really should launch these through Neil Cooke. they're really good. Put your name in them & contact info as a comment.
    @billy2
    Do you like the way the opEdgeChange UI populates?
    @billy2
    I have now named the features as follows:
    opExtendSheetBody:    Extend Surface
    opEdgeChange:            Change Edge
    opCreateOutline:          Project Body
