I'm stuck on something I'm sure is simple
EvanReeseEvanReese Member, Mentor Posts: 2,421 ✭✭✭✭✭
Hi everyone. I've got essentially zero coding experience, so I hope I'm missing something that will be obvious to people. I'm trying to write a script that will find all of the sharp edges of a body and highlight them with the debug function. This will help me evaluate models before I send them off for injection molding since no edges should be sharp except shutoffs. Here's what I have so far, but I'm not getting any red edges:
<div>FeatureScript 961;</div><div>import(path : "onshape/std/geometry.fs", version : "961.0");</div><div><br></div><div>annotation { "Feature Type Name" : "Find Sharp Edges" }</div><div>export const findSharp = defineFeature(function(context is Context, id is Id, definition is map)</div><div>&nbsp; &nbsp; precondition</div><div>&nbsp; &nbsp; {</div><div>&nbsp; &nbsp; annotation { "Name" : "Body to Search", "Filter" : EntityType.BODY && BodyType.SOLID, "MaxNumberOfPicks" : 1 }</div><div>&nbsp; &nbsp; definition.body is Query;</div><div>&nbsp; &nbsp;&nbsp;</div><div>&nbsp; &nbsp; &nbsp; &nbsp;&nbsp;</div><div>&nbsp; &nbsp; }</div><div>&nbsp; &nbsp; {</div><div>&nbsp; &nbsp; var smooth is Query = qOwnedByBody(definition.body, EntityType.EDGE && EdgeConvexityType.SMOOTH);</div><div>&nbsp; &nbsp; var all is Query = qOwnedByBody(definition.body, EntityType.EDGE);</div><div>&nbsp; &nbsp; var sharp is Query = qSubtraction(all, smooth);</div><div>&nbsp; &nbsp; debug(context, sharp);</div><div>&nbsp; &nbsp; });</div>
  • EvanReeseEvanReese Member, Mentor Posts: 2,421 ✭✭✭✭✭
    edited December 2018
    for some reason the formatting above looks wrong, so here's the code without the "code" formatting in case that helps:
    FeatureScript 961;
        precondition
  • pmdpmd Member, Developers Posts: 64 PRO
    I do not think you can use EdgeConvexityType like that (&&-ed in). You probably need to loop over all edges for a body and call evEdgeConvexity()  on each edge individually.
    I think that makes sense. Is it right to think of the query is kind of like the container of the edges, so it isn't convex, or smooth? If so I need to unpack the container and look at each edge. By "loop" do you mean a "for loop"? Not sure how to approach that. I was able to query all edges and get that to show up red.
    as @pmd said you need to pass a query of edges to filter laminar edges, not the body query. and you can't use logical argument combinations inside.
    var smooth is Query = qOwnedByBody(all,  EdgeConvexityType.SMOOTH);
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,868
    Not sure if this is the most efficient way, but it works:
        precondition
            var sharp = [];
            var allEdges = qOwnedByBody(definition.body, EntityType.EDGE);
            for (var i = 0; i < size(evaluateQuery(context, allEdges)); i += 1)
                if (evEdgeConvexity(context, { "edge" : qNthElement(allEdges, i) }) != EdgeConvexityType.SMOOTH)
                    sharp = append(sharp, qNthElement(allEdges, i));
            debug(context, qUnion(sharp));
    By the way, to get the code block to work in a post like this, set it to code first then paste your code into the block.
    @Evan_Reese
    To get the code to paste correctly, you should hit the "code" formatting option, then paste your code into the blank yellow box that appears (not paste the code then highlight and press the "code" button).
    This is the code that you want:
    var sharpArray = [];
    // This is a query that represents all the edges of the body
    const allEdges = qOwnedByBody(definition.body, EntityType.EDGE);
    // This is an array of queries.  Each query in the array represents one of the edges of the body (the array is
    // in an arbitrary, but deterministic, order)
    const allEdgesArray = evaluateQuery(context, allEdges);
    // Now that you have an array of each edge, you can loop over it
    for (var edge in allEdgesArray)
        const convexity = evEdgeConvexity(context, { "edge" : edge });
        if (convexity != EdgeConvexityType.SMOOTH)
            sharpArray = append(sharpArray, edge);
    // at this point sharpArray is an array of queries for sharp edges.  To combine it into one overarching query, use qUnion:
    const sharpQuery = qUnion(sharpArray);
    debug(context, sharpQuery);
    // In shorthand:
    for (var edge in evaluateQuery(context, qOwnedByBody(definition.body, EntityType.EDGE)))
        if (evEdgeConvexity(context, { "edge" : edge }) != EdgeConvexityType.SMOOTH)
    debug(context, qUnion(sharpArray));
    <br>
    That's definitely getting me closer. Thanks! with this code, I should be able to view all of the smooth edges by debugging, but I'm not having any luck. Here's what it looks like
        debug(context, smooth);
    sorry, i copied your code unattentively, and thought query for convext edges exist in standart library, but I was wrong, so you really need to iterate through a list of edges and check each with evEdgeConvexityType()
    @konstantin_shiriazdanov no worries, and thanks for the help!
    @Jake_Rosenfeld this looks like a good solution, but I don't have time to dig into it right now. Thanks for the help!
    @NeilCooke Thanks! I'll look into this sometime soon, and compare your and Jake's solutions to see what I can learn. For now, I've got actual deadlines on some other stuff.
    Jake’s solution is better  :)
