I'm stuck on something I'm sure is simple
EvanReese
Member, Mentor Posts: 2,695 PRO
Hi everyone. I've got essentially zero coding experience, so I hope I'm missing something that will be obvious to people. I'm trying to write a script that will find all of the sharp edges of a body and highlight them with the debug function. This will help me evaluate models before I send them off for injection molding since no edges should be sharp except shutoffs. Here's what I have so far, but I'm not getting any red edges:
<div>FeatureScript 961;</div><div>import(path : "onshape/std/geometry.fs", version : "961.0");</div><div><br></div><div>annotation { "Feature Type Name" : "Find Sharp Edges" }</div><div>export const findSharp = defineFeature(function(context is Context, id is Id, definition is map)</div><div> precondition</div><div> {</div><div> annotation { "Name" : "Body to Search", "Filter" : EntityType.BODY && BodyType.SOLID, "MaxNumberOfPicks" : 1 }</div><div> definition.body is Query;</div><div> </div><div> </div><div> }</div><div> {</div><div> var smooth is Query = qOwnedByBody(definition.body, EntityType.EDGE && EdgeConvexityType.SMOOTH);</div><div> var all is Query = qOwnedByBody(definition.body, EntityType.EDGE);</div><div> var sharp is Query = qSubtraction(all, smooth);</div><div> debug(context, sharp);</div><div> });</div> 0
annotation { "Feature Type Name" : "Find Sharp Edges" } export const findSharp = defineFeature(function(context is Context, id is Id, definition is map) precondition { annotation { "Name" : "Body to Search", "Filter" : EntityType.BODY && BodyType.SOLID, "MaxNumberOfPicks" : 1 } definition.body is Query; } { var sharp = []; var allEdges = qOwnedByBody(definition.body, EntityType.EDGE); for (var i = 0; i < size(evaluateQuery(context, allEdges)); i += 1) { if (evEdgeConvexity(context, { "edge" : qNthElement(allEdges, i) }) != EdgeConvexityType.SMOOTH) { sharp = append(sharp, qNthElement(allEdges, i)); } } debug(context, qUnion(sharp)); });By the way, to get the code block to work in a post like this, set it to code first then paste your code into the block.To get the code to paste correctly, you should hit the "code" formatting option, then paste your code into the blank yellow box that appears (not paste the code then highlight and press the "code" button).
This is the code that you want:
var sharpArray = []; // This is a query that represents all the edges of the body const allEdges = qOwnedByBody(definition.body, EntityType.EDGE); // This is an array of queries. Each query in the array represents one of the edges of the body (the array is // in an arbitrary, but deterministic, order) const allEdgesArray = evaluateQuery(context, allEdges); // Now that you have an array of each edge, you can loop over it for (var edge in allEdgesArray) { const convexity = evEdgeConvexity(context, { "edge" : edge }); if (convexity != EdgeConvexityType.SMOOTH) { sharpArray = append(sharpArray, edge); } } // at this point sharpArray is an array of queries for sharp edges. To combine it into one overarching query, use qUnion: const sharpQuery = qUnion(sharpArray); debug(context, sharpQuery); // In shorthand: var sharpArray = []; for (var edge in evaluateQuery(context, qOwnedByBody(definition.body, EntityType.EDGE))) { if (evEdgeConvexity(context, { "edge" : edge }) != EdgeConvexityType.SMOOTH) { sharpArray = append(sharpArray, edge); } } debug(context, qUnion(sharpArray)); <br>The Onsherpa | Reach peak Onshape productivity
@Jake_Rosenfeld this looks like a good solution, but I don't have time to dig into it right now. Thanks for the help!
@NeilCooke Thanks! I'll look into this sometime soon, and compare your and Jake's solutions to see what I can learn. For now, I've got actual deadlines on some other stuff.
