How do I rotate a sketch 90 degrees?
Member Posts: 7
I started my sketch in the front view.  My 3D printer software needs the part in the top view.  How do I rotate my part 90 degrees so it appears properly in the Top View?
  • Member, OS Professional, Mentor Posts: 2,476 PRO
    @jim_thompson
    You can simply change the plane for your sketch. To do this, go to edit your sketch and delete front plane; then click top plane instead.
  • Member Posts: 7
    I first tried selecting the plane and hitting the delete key.  That deleted everything.  I finally discovered that the front plane was listed in the box below sketch 1.  I then deleted and selected Top.  Its easy once you know how to do it.  Thanks
