Offset Spline Distance
Splines in a 2D parametric sketch solver are somewhat different than what you can do with a truckload of tarmac
I would suggest splitting the spline where the areas of high curvature are, offset them, then manually trim them afterward. That will give you sharp vertices that you can fillet if you want.
