Is the eu-west-1 server down?
Since one hour ago I can't access my documents. Using the system check (https://cad.onshape.com/check) shows that there is a web socket error. According to your forum this could be due to port 443 being closed. So I double checked by using a completely different network (4G on my phone) and the issue persited. So I doubt it is a port 443 issue in this case. I'm using the eu-west-1 server. Is this server fully operational?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,848
    Yes euw1 is down at present, working on it now. You can see the status at status.onshape.com
    Sorry for the inconvenience.
  • YWCYWC Member Posts: 13 PRO
    Hello there. Is the eu-west-1 down? Can not access my documents.
    @3d.2 are you still having problems? Seems OK here.
    It's all right now. thanks.
  • DemiandeKeijzerDemiandeKeijzer Member Posts: 3 PRO
    Is the EU-West-1 down because i have trouble with the connection?
    edited March 2019
    @DemiandeKeijzer - it is working for me, can you retry?
    Same here, just submitted a ticket.
    I'm seeing some disconnects and generally poor performance when working.
    OK, seems that there were intermittent issues with servers in euw-1 and elsewhere. Apparently, the automatic scaling feature that adds more compute power to address service demand was not working as expected. Resolved now. Apologies for the inconvenience.
    You can keep track of any service issues here: https://status.onshape.com
    Thanks Neil, my ticket was addressed quickly and the issue resolved.  Good work folks.
