Pipe feature
andy_morrisandy_morris Moderator, Onshape Employees Posts: 87
We've had requests for a pipe feature, so you can avoid the current create plane --> create profile sketch --> sweep workflow.
Thanks to @ilya_baran and the wonders of FeatureScript, here is a custom feature for pipes.
https://cad.onshape.com/documents/153cc3c8228c34a47f0b88d5/v/584ae1f362b4922e7cec3fe2/e/56f7232dfddc387a4c9e3f9c
Just select the path from edges or sketches and set the OD and ID.
Andy Morris / Head of Product Design / Onshape, Inc.
    That's really rather good, and presumably will rebuild just fine if upstream dimensions are changed, just as long as ID's stay the same?
    OwS
  • andy_morrisandy_morris Moderator, Onshape Employees Posts: 87
    Yes, its just like any other Onshape feature in that regards.
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,175
    The latest version (V4) has been updated to also support disjoint straight pipe segments with mate connectors.
    @andy_morris
    If feature scripts are so easy....why don't you guys just make this (and others) standard functionality?
    If every custom feature we wrote was added to the standard library, it would be a big polluted mess!
    A good place to say "thank you" for making featurescript so close to the user that we can make "mess" for ourselves. No any other CAD that has scripting environment in a list of standart invironment types on the first page of the project.
  • MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,034 EDU
    edited December 2018
    @ilya_baran
    @andy_morris
    @Jake_Rosenfeld
    Here is a pipe feature that works with multiple paths in the one feature (I created my own constructPaths feature)
    https://cad.onshape.com/documents/e89f406ea0fb1b1a9225a055
    PS: Thank you for FeatureScript, otherwise none of this would be possible :)
  • Tony_C_Tony_C_ Member Posts: 272 PRO
    Cool.  Now can you make it put in all the fittings too?  ;)
    Great stuff @mbartlett21 !
    @Tony_C_
    Can you give an example? :)
    I have just made the constructPaths library public (I didn't realise it was private)
    https://cad.onshape.com/documents/3021561771935e716a44c1b1
    @mbartlett21
    Very cool!
    Botanist cool?
  • sebastian_glanznersebastian_glanzner Member, Developers Posts: 398 PRO
    The pipe feature is really nice!
    You can use it to make compression springs based on helix features:
  • wout_theelen541wout_theelen541 Member, csevp Posts: 198 PRO
    I just took a look at the FS there's an error generating the pipe in your example part studio
  • robert_barber444robert_barber444 Member Posts: 2
    Is there a way to use this feature with a tapered and bent pipe? I am trying to model a pipe that is 1" on the left end, has a slight bend, and smoothly tapers out to 2" at the right end
