Unexpected Behavior of floor function
nicholas_aarestad
Member Posts: 14 EDU
I've been experimenting with using the floor and ceiling functions for various instance counts, and there's one behavior that's got me scratching my head.
I have a configuration variable called #length.
When I use this in a Pattern Feature feature, I use this like floor(#length/in)
For most values, this works fine-- except that for integers, the value is 1 less than the actual value.
For example for #length = 24 in, the function returns 23. ceil() seems to be unaffected.
If I just directly input the value as 24, I get the expected floor(24)=24.
Is there something weird going on here with the unit division?
Apologies if this has already been asked about, but I couldn't find anything in the documentation or previous threads about this.
Can you try using
floor(#length/in+TOLERANCE.zeroLength)
insteadIR for AS/NZS 1100
Maybe @lougallo would know
