When selecting multiple parts, page fails to load and I get an "Oh no page fails....." notice.
bari
Member Posts: 11 EDU
I have tried this with documents that previously have worked, and from several computers and different internet connections. Has something changed? I realize it has to do with the amount of parts selected, small assemblies are selected successfully, but still larger assemblies that were previously selected are failing and I have tried this on several hardware and internet connections that should be sufficient.
NeilCooke
Moderator, Onshape Employees Posts: 5,926
No, nothing has changed. Can you make sure that Chrome and your graphics driver are up to date then if it still persists please open a support ticket.Senior Director, Technical Services, EMEA5
If you are box-selecting in a Part Studio it will try to select all the edges and faces as well as the parts. This can take some time if there are thousands. If you pick the parts from the feature list it is much faster.
This is happening with files that I have worked with before succesfully.
Has something changed? Is there a change in the processing copacity between onshape free and proffesional?
Fierfox is better, but takes over a minute per selection....
