Copy part studio
Could anyone say if it is possible to copy a part studio from one document to another. I have tried the copy to clip board command but cannot find how to paste from clipboard into the new document. could someone
point me in the right direction please.
Thank you Brian.
Thank you Brian.
NeilCooke Moderator, Onshape Employees Posts: 5,866
Paste is in the + menu bottom left corner.Senior Director, Technical Services, EMEA5 -
Jake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646
@brian_pinder662
Are you sure you want copy/paste? This loses all associativity between the Part Studios. Are you sure you don't want derived:
https://cad.onshape.com/help/Content/derived.htm
Jake Rosenfeld - Modeling Team5 -
@brian_pinder662
If you are just trying things out with a design, may I suggest branching? It will allow you to branch into a number of different design iterations and then merge back the one you like without leaving your document.
https://www.onshape.com/cad-blog/tech-tip-branching-designs
Also Jake, As it happens no associativity is what I need as I am only trying different things out, However now I know it is the derived feature I need to keep associativity. Once again thanks for your help Brian
Brian
