Flexible Part
sam_biddle
sam_biddle Posts: 20 ✭✭
I am creating this cup that has flexible corners (where the fillets are) that will be made out of rubber.  The cap on the bottom will be magnetic and once it is put on, the cup will keep its hexagonal shape.  I want to show the cup collapsing flat once the cap on the bottom is removed.  Is there a way to do this?  Thank you.
