Flexible Part
I am creating this cup that has flexible corners (where the fillets are) that will be made out of rubber. The cap on the bottom will be magnetic and once it is put on, the cup will keep its hexagonal shape. I want to show the cup collapsing flat once the cap on the bottom is removed. Is there a way to do this? Thank you.
Other than that, someone may be able to make a FeatureScript for that.
https://cad.onshape.com/documents/21fa541ca92d7d95aea12b6d/v/8b31dd78d7faf7097352ce7b/e/a7050d236d39980ebd6a0bc3
The sides of the cup are equal lengths. I have the cup folding up with symmetry, but you could control the angle with a config like Neil suggested.
