Loft tool and Remove
Greetings,
For your consideration and suggestions:
Ok, here I have a solid that was created using the revolve tool.
Now I want to use the loft tool to cut a vane from inside. I have two profiles in one drawing and a spline path that is projected from the sketch below.
If I use the loft tool in Add mode without the part shown, I get this. So far so good.
With the part shown and used as a merge tool, but still in Add mode
Now in Remove mode. What did I do wrong? I've tried this about seven ways and wind up in the same place each time.
Thanks,
Isotherm
Now in Remove mode. What did I do wrong? I've tried this about seven ways and wind up in the same place each time.Thanks,
Isotherm
IsoTherm
Member Posts: 68 PRO
got it figured out. I needed to start the cut profile beyond the hard edge.0
Thanks,
Isotherm
Leave a Comment
https://cad.onshape.com/documents/66cce4f0bbb0283c15e6e72b/w/bc8924ea6ab6e27b2f023eef/e/b5ee68611e35574481db2156
