Feature Folder: Smarter Drag
EvanReese
Member, Mentor Posts: 2,693 PRO
I love the new feature tree folders! I've been wanting them for a while, so huge thanks to the Onshape dev team for getting them implemented. I noticed that when you drag a feature into the folder, it automatically lands at the top of the folder. I'm usually dragging them in from below because that's where new features are born. This means I have to drag it in, then expand the folder and move it to the bottom manually. It would be awesome if the folder knew whether the feature came from above or below the folder and would put it at the top or bottom depending on which. If someone has a cleaner workflow to add features to an existing folder, I'd love to hear it.
