Sketching on New Plane
geoff_josey
Member Posts: 68 ✭✭
in General
I have a rectangular block with two holes thro the block. The original rectangle was on the top plane.
I now want to create 2 cut outs centered on each hole. When viewed from the bottom I create a new sketch, but when drawing lines to the outside of the block (rectangle as in original sketch which was used for the extrusion) There does not seem to be a line to meet. When you extrude is the new edge not created ?
Sensor Mount X Axis
https://cad.onshape.com/documents?resourceType=filter&nodeId=1
Sensor Mount X Axis
It should be something like
https://cad.onshape.com/documents/12312312345abcabcabcdeff/w/a855e4161c814f2e9ab3698a/e/459d631d67c38b8d80944f2f
https://cad.onshape.com/documents/2258500c16af1bee0560d432/w/12daed955e3e0f47b42530c4/e/3d8d18f298622
Are you saying that I am not conforming to the guidelines ? I have read them via your link.
Thanks
I made a copy of your document
https://cad.onshape.com/documents/9fc1dee378020e00e5a7b953/w/7bee8c770d7290726f44dcdb/e/9e69fee1751735ee949b478f
Is this what your trying to do??
If you are looking for something else, here's a link to some starting video's,
https://www.onshape.com/videos/topic/intro-to-cad
Good luck
Thanks
I have made another copy of your file,
https://cad.onshape.com/documents/3612e1c4f71f206ec324fee8/w/8829098b3990e98ab121eeb3/e/aa60c821159e15824ecee184
In Part Studio 2 you can see a different aproach, only model half if your part is symetric, that save's time.
The first sketch is fully constraint, that,s a good practice.
In the second sketch you select the contourlines and the hole, and use the üse command.
For using the tangent command, first select the straight line and then the circle.
After finishing the extrude, mirror the part and select add, not new.
Good luck
