Dimensioning
derek_stonederek_stone Member Posts: 4
What is the most efficient method of adding dimensions to this frame?  I was hoping to use a chain dimension but cannot locate an option like that in onshape.https://cad.onshape.com/documents/b91f9b0ed241405649002bae/w/c0ba82c72402fc1d25ee2c68/e/ada853b04c3ddc690f93c3ff
  • MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,055 ✭✭✭✭✭
    Do you mean ordinate dimension in a drawing?
  • billy2billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,087 PRO
    like @mbartlett21 says, you can use ordinate (left) or change to the dim's on the right. You can't have both.
    Watch your tolerances, add something to the title block for tolerance ranges. I'd make the views bigger.
    Detail out the welds, I'd add some straightness and perpendicularity callouts. Add some notes with material, finish and possibly some grinding instructions. Add callouts for which beams you're using. Not sure the right view is necessary.
    If you rotate primary view 90 degrees, it fits the page better.
