Detail on crank
tarek_mustafa
Member Posts: 40 ✭✭
in General
Hallo,
I struggle to get the winding on my crank.
In a first attempt I thought to put a Helix on the crank and than cut it in the length I need it but I could find a way to realise it.
Any help to solve this problem is much appreciated.
Best regards,
Tarek
Best regards,
Tarek
Optionscoleman OS Professional Posts: 244 ✭✭✭Hi Tarek,
Going off the sample picture, the crank shaft has a bigger OD where the threads are and it is relieved on each end. You will need to grow the diameter that interfaces with the worm gear (revolve around centerline). Then you can add the helix to this new larger region. This will be the major OD of the drive.
Next, sketch the profile of the thread (looks like an Acme) on a plane tangent to the start point of the helix and Sweep cut (remove) using the sketch profile and the helix as the path.
Then you will end up with something like this:
To recap:
1) Increase major diameter of crank in middle section (revolve sketch around centerline)
2) Add helix to new section on crank (this will limit the helix length and it will be slaved to the bigger diameter)
3) Draw thread profile (acme thread) on a plane tangent to the start of the helix. You can dimension for the correct depth (minor diameter)
4) Sweep the sketch with the helix as the path and select the bigger diameter as the merge with
Good luck
The music box is looking great!
1
UPDATE: Maybe I should read the entire post.... Sorry. Yes look at @Coleman 's answer.
You can add that normal plane by adding a new plane with "Curve point" selected the endpoint of the helix and the helical curve.
To recap:1) Increase major diameter of crank in middle section (revolve sketch around centerline)
Good luck
