Converting sheet metal parts from other CAD system
kent_henderson
Member Posts: 71 PRO
in General
Take a look at this sheet metal step assembly I've imported from another CAD program. What you'll see is exactly how the import came into Onshape except I've hidden all but one part in the design studio for clarity, and I group constrained the parts in the assembly. I'm impressed with the imports integrity. My question is this..... What's the best way to covert the imported SM part called Valve Cover Body into something I can flatten and modify in Onshape.
https://cad.onshape.com/documents/aed3d3850b326223877df48a/w/1baac759470f104a92af513a/e/28b944c1bea014f160e1dccf
EDIT: Just tried that and it didn't work - let me get back to you
EDIT: There's something in the bend geometry that Onshape doesn't like (we'll take a look at it in more detail). The process detailed above works fine on geometry exported then imported back into Onshape. Another way this can be done, but it takes a little more effort, is to use Delete Face on all internal and external bends. Then use the technique above - you cannot use "tangent propagation" anymore, so you will have to select each face, then select the sharp corners to add bends.
https://cad.onshape.com/documents/2a21c718f8a54f17d8b2fe8d/w/125b1cb6b0d5201caaf7a0ba/e/3275417cb2835cad20b69722
@brucebartlett
@NeilCooke
Please try the recognize feature on my FeatureScript here:
https://cad.onshape.com/documents/a39db7615a2a945ffb7076c3
It will allow you to set a custom thickness, and if you do, it will also allow you to set bend allowance or deduction.
Would you like mine to delete the curved faces automatically?
