How to sketch a sin wave along a circle like this tool
hello,
i need to draw this tool but i have no idea how can i reproduce the inner part of this tool (see picture).
any advices would be welcomed.
thanks
thanks
you could make this with some curve scripts but you could also just use circle arcs
https://cad.onshape.com/documents/57f3ddd19d44f3c0031903a6/w/b499a2024fc0a55653bae772/e/db0b472b46edd36e57cf4f17
1 -
NeilCooke Moderator, Onshape Employees Posts: 5,878
Yes, from the image it looks like just circles not a sine wave - easy to model https://cad.onshape.com/documents/235120b2860379b7320cdf1cSenior Director, Technical Services, EMEA7
what are the steps ?
- create the two variables a and d
- in the sketch create two construction lines with the angle constraint depending on a and the length depending on b
- create a curve generator defining the range of a and selecting d
this is what i did but the curve is not drawn
also notice that my #dl variable contains expression which depends on #a value: 2.5*sin(20*#a*deg)
and then once i have it how to create a solid from the curve ? I can't extrude ?
