How to sketch a sin wave along a circle like this tool
alexandre_vallette
Member Posts: 5 PRO
hello,
i need to draw this tool but i have no idea how can i reproduce the inner part of this tool (see picture).
any advices would be welcomed.
thanks
thanks
Optionskonstantin_shiriazdanov Member Posts: 1,221 ✭✭✭✭✭you could make this with some curve scripts but you could also just use circle arcs
https://cad.onshape.com/documents/57f3ddd19d44f3c0031903a6/w/b499a2024fc0a55653bae772/e/db0b472b46edd36e57cf4f17
1 -
OptionsNeilCooke Moderator, Onshape Employees Posts: 5,419Yes, from the image it looks like just circles not a sine wave - easy to model https://cad.onshape.com/documents/235120b2860379b7320cdf1cSenior Director, Technical Services, EMEAI7
what are the steps ?
- create the two variables a and d
- in the sketch create two construction lines with the angle constraint depending on a and the length depending on b
- create a curve generator defining the range of a and selecting d
this is what i did but the curve is not drawn
also notice that my #dl variable contains expression which depends on #a value: 2.5*sin(20*#a*deg)
and then once i have it how to create a solid from the curve ? I can't extrude ?
