Is it possible to specify layer colours on sheet metal DXF export?
Transistor
Member Posts: 13 ✭✭
in Drawings
I'm using sheet metal mode to design cardboard boxes. I export the DXF and import to my laser software, LaserWeb4 which I have set up to use blue lines for marking fold-lines and black for cutting.
Can anyone think of a way of configuring OnShape to export DXF with the fold lines set to a colour other than black?
Not on the export, but you can change the color code after generating the dxf file using notepad.
Refer this thread: https://forum.onshape.com/discussion/21721/changing-line-color-of-exported-dxf
