Section View Grab Handle / Triad improvements
 owen_sparks
                    Member, Developers Posts: 2,660 PRO
owen_sparks
            Hi folks.
I'm a touch frustrated with the grab handles for a section view in a PS.
(a) If zoomed in then the handle is often off the screen.
(b) If viewing normal to the section plane then we can't see the handle to push/pull the section, so have to rotate the view away from normal and then back again.
Just in passing, I presumed I was missing something so tried looking at the help.  a search of "section view" returned 38 hits but I couldn't see anything on PS section veiws other than stating that it was an option.
Other features of the section view, like snapping to the center of a circle are wonderful so with a few tweaks it'd be perfect.
Cheers,
On the second situation where you are normal to the face, you will see the dot, Is this a common situation?
You can drag the arrow, then view normal to the section view, then scroll in the text box that comes up
