Can a named view be setup in an assembly that can be used accross all documents?
 tristan_flintoff
                    Member Posts: 12 PRO
tristan_flintoff
                                  in Drawings
                    Is it possible to setup a named view that is a template that can be used across all of my documents in Onshape?
             philip_thomas
                            Member, Moderator, Onshape Employees, Developers Posts: 1,381 philip_thomas
                            Member, Moderator, Onshape Employees, Developers Posts: 1,381 Yes! Very easy Yes! Very easy
 Method 1) Set up a new blank document with the views you want. Whenever starting a new document, just copy the workspace of this one - the assembly element will now have the named views. This is akin to building a 'template'.
 Method 2) Set up the 'template' as before and 'copy to clipboard' the assembly element. Now whenever you want to create an assembly in a new document, click on the '+' in the bottom left hand corner and select 'paste tab' - boom!
 These are two very easy ways to get what you want Philip Thomas - Onshape3 Philip Thomas - Onshape3
Thanks........works well
