Increase duration of time before "system timeout"?
I often switch to doing other things while working on a CAD model in Onshape, it's inconvenient to have to refresh the browser every time there's a "system timeout". Is it possible to increase the duration of inactivity required for system timeouts to occur?
2
(sorta like touching your screen on your phone to keep it from locking)
but that doesn't seem to be enough and it will still time out.
What is the minimum input required to start the timeout counter?
So, I should just double-tap J or K then eh?
