View normal to, Android
famadorian
Member Posts: 390 ✭✭✭
in General
This view normal to,, is that not available in Android ?
john_mcclary
Member, Developers Posts: 3,981 PRO
select a plane or surface you want to view normal to, then with two fingers, tap into white space to bring up the context menu.
it will be on the bottom
1
The stylus I use is the one with the galaxy note. I know it doesn't
