Dashed lines on some parts in assembly but not others?
I have a fairly simple assembly that has 5 parts. What seems confusing is that only one of the parts shows dashed lines on its hidden geometry while the other four do not. I can't see what's unique about the part that has dashed lines. The part in question is "top plate" in the linked drawing, which I have made public.
https://cad.onshape.com/documents/90b51cb43367462cbdb20f18/w/dd05c1f85905449f95212432/e/1785d0db78714c2fa12f748c
An unrelated question is, "Is this the best way to point to a drawing when asking help?"
Thanks
Thanks
3dcad Member, OS Professional, Mentor Posts: 2,476 PRO
@Len When you do a sketch and extrude Ons automatically hides the sketch. You can set sketch show/hide using the eye- icon when hovering feature tree.
In your document, I can see visible Sketch 5 (dashed line in yellow part), Sketch 6 and Sketch 9 - try hiding those to make dashed lines disappear.
For unrelated question, I could not think of easier way to help anyone / asking for help than sharing a model.
//rami5
If we all help each other when possible, we will free up resources for Ons to build us better tools..
<<If we all help each other when possible, we will free up resources for Ons to build us better tools.. >>
An unerring sense for the common good from @3dcad. Kudos is appropriate, I reckon, along with (hopefully) emulation
