Unwanted linking of version/history tree between duplicated part studios
Cedric_Eveleigh
Member, OS Professional, csevp Posts: 73 PRO
I duplicated a part studio and now when I change the version/history tree of one, it creates an equal change to the version/history tree of the other, even if the parts in the two part studios are now different. I really do not want this; it makes the duplicate part studio feature unusable to me. Is there any way to avoid the linking of version/history trees?
Yes, I was hoping to have part studios in the same document with different version/history trees. From what you're saying, it sounds like that's not possible. And to answer your question, physical changes were not propagating between my duplicated part studios, but changes to the version/history tree were. Thanks for your reply.
Just to confirm, History is at the document level. If you want to explore different design iterations for that Part Studio, consider making a version, and then branching into two or more different branches to represent different designs. Then you can merge back the one that ends up being the best.
