Extrude Fails
famadorianfamadorian Member Posts: 390 ✭✭✭
I was on a roll, creating lots of lofts and then extruding them, then suddenly it wouldn't work on one and it just throws the normal non-intuitive "can't regenerate" message.
Is there any way to get more sensical error messages so that I can figure out what's wrong?;)
Here's the public document:
https://cad.onshape.com/documents/70d70cf1b954c030847ece24/v/569d1fc66d020cf1308e7410/e/d8b4ad7ea70fdf1769c91ad4
    @famadorian
    The face may not be quite planar.
    Pease try this FS, which supports non-planar faces:
    https://cad.onshape.com/documents/24819ddab7dc83c810eb8246
    You may have to specify a direction using two points or a directional face
    The loft is between two straight curves, so the face must be planar? Also, why doesn't the error tell me it's not planar, if that's the problem?
    Also, not sure what you mean with FS? I looked at your document, but it doesn't use a FS function?;)
    If you look at the vertices (and their resultant unit vectors), the loft doesn't create a planar surface:
    vertices:
    v1 = [-835.72000, 6578.46498, -1243.00003]
    v2 = [-835.72000, -2009.53507, -1243.00003]
    v3 = [-835.72000, 6578.46498, -4668.00022]
    v4 = [-835.70999, -2009.53507, -4668.00022]
    line vectors:
    l1 = (v2 - v1) =[0, 1, 0]
    l2 = (v4 - v3) = [-1.16558×10^-6, 1, 0]
    Going from l1 to l2 will require a twist, which makes the resulting surface not planar.
    Jake Ramsley
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,068 PRO
    That is weird.
    But Thicken does work, and is probably more appropriate for what you are doing anyway
    @famadorian
  • famadorianfamadorian Member Posts: 390 ✭✭✭
    @famadorian
    @famadorian
    It does not tell you it isn't planar. It just doesnt accept the selection.
    The faces and sketch regions to extrude box in your extrude is empty.
    My document has a FS feature that you can add to your toolbar called Extrude
    It allows you to specify a direction and also do a thin-feature extrude
    @famadorian
    vertices:
    line vectors:
    Jake Ramsley
    Really, all the lofts and extrudes are overkill
    just extrude your surfaces, then thicken
    https://cad.onshape.com/documents/d42e6f41dfe15f73214cc08f/w/9f4e16f982213c9119a76ed0/e/85c5608385533392b45428ce
    Turn 50 features into 2
    That is weird.
    Thicken it is;) Thank you
    @famadorian
    Ah, it's a FeatureScript called Extrude in there;) Got it; thanks.
