Optimizing an unsupported screw hole for a 3D printed enclosure
mauronic
Member Posts: 9 ✭✭
I have a hole for an M3 screw and I simply ran a column from the top of my enclosure to the bottom. Obviously not ideal. I would like to model something that receives a short screw and then tapers at < 45 degree angle to the sides. This will save a little material, weight and reduce print time.
I am having a problem elegantly constraining the bit to the corner as well as tapering it. In other words, it's offset and too long now. I guess I could create a shape and do a 90 degree revolve but I am looking for ideas for the most elegant solution.
Hope this makes sense. I can share my drawing if that helps. Not sure if sharing publicly is view only.
pete
pete
Thanks for taking the time to sketch and share and turning me on to projection which which I will have to experiment with. I was actually interested in tapering the whole thing about 10-15mm from the top so nothing wold go through to the bottom. See pic.
If this is going to be cast in metal again there is a problem with negative draft.
If You are going to 3D print the part the corners will be stronger with corners as @Onshaper example.
Dave
Ariel, WA
https://cad.onshape.com/documents/82aebba0966b445db58af166/w/3a0ab869c6644b0390969263/e/32753111666f47ea9e538385
that is closer, right?
I know it's not perfect, but it should be very 3D printer friendly
edit: added second one into the same model, now i think it should be almost exactly what you want
I took the 2.5mm wall thickness as a constraint; one might be able to do interesting things with an open hole...
https://cad.onshape.com/documents/3a83fc705ab24c77907c79d7/w/792043e2de8e4d64b5dc1a86/e/de1d84a3931e46cb8e075ddd
