Can the precision for angularity red reduced when using mate connectors?
Reece_Isaac
Member Posts: 43 ✭✭
I know my question title doesn't explain at all so I shall try to expand.
I have been having great trouble with an assembly trying to connect several parts that involves 3 revolute and 1 cylindrical mate connectors. Which invariably fail. I have tried different types and combinations of mate connectors and came to a conclusion that something wasn't inline. Today I replaced a fasten mate with a planer mate (with some limitations on some axis) and lo and behold the assembly doesn't fail and can be manipulated. To try and see why this worked I picked two parts to see what the measurement was. These should be parallel. It seems that they are at and angle of 0.004 degrees! This is a ridiculous degree of accuracy to cause a mate to fail. I have attached two screens of the problem, the top image is with the Planer connector the bottom with the fasten connector. Note the the revolute connectors fail with the part fastened and the misalignment is 0.004deg.
NeilCooke
Moderator, Onshape Employees Posts: 5,922
You probably already know this, but it’s the blue part that is at fault. I couldn’t open (or find) the linked document. Is it private? Looks to me like an imported part? I think the shafts are not coaxial and certainly the ends of the shafts are not parallel. Creating a mate connector in the part that uses the shaft axis rather than the end of the shaft will probably fix this.Senior Director, Technical Services, EMEA6 -
NeilCooke
I just measured a ton of faces to try to find where the angle came from. I may not have found it so quick without the tip from you.Senior Director, Technical Services, EMEA5
