Removing an "asymmetric Pyramid from solid" (Constructing a hip rafter)
joerg_arnold
Member Posts: 4 EDU
Dear All,
I'm kind of new using Onshape and got stuck by trying to construct a hip rafter for an awing (shown in the picture below).
My Problem is the following:
I have created a balk as a solid in Onshape. Now I have to remove some kind of an "asymmetric Pyramid" in such a way that the hip rafter fits to the corner of the two horizontally aligned balks (red circle, picture below on the right) .
How can this be done in Onshape?
Hope that I explained the problem clear enough...
I am thankful for any help and information!
Thanks!
Thanks!
owen_sparks
Member, Developers Posts: 2,660 PRO
Ok, here is a copy of your file:-
You'll see I've:-(1) Changed your extrude2 to "New" from "Add" so that it creates a separate part.(2) Added a boolean feature to cut away the new part from the old part. (I've added an offset to give a tolerance with the offset face option.)Does that help?Cheers, Owen S.Business Systems and Configuration Controller
HWM-Water Ltd6
Onshape, Inc.
Here is the document url:
https://cad.onshape.com/documents/ac36b4c9dcb9af7d189aae9b/w/bcab52b58daa7cc952da01bc/e/48a3d210a5866b7a9915b4e4
Yes, I wanted to try the Boolean feature, but had problems to find the right workflow to apply it properly
Because Onshape has multi-part part studios, Tim is suggesting that you just model the balks and the hip rafter in the same Part Studio, and use a subtraction. Is there something specific that is causing you trouble?
https://cad.onshape.com/documents/af9b1d618a95b109024e900b/w/0e40139928c46f072effaafe/e/d705bc705c632340ed711c72
@Jake_Rosenfeld :
I was able to replicate your example of subtracting to bodies by using the Boolean tool. Thanks!
Afterwards I tried to apply this to my project. I created a rectangular tool that i wanted to subtract from the target (which is the "hip rafter"). As i tried to apply the Boolean operation i couldn't select the tool and the target as single parts. I just got one selectable unit out of both parts!
What did I wrong here?
my document url:
http://cad.onshape.com/documents/ac36b4c9dcb9af7d189aae9b/w/bcab52b58daa7cc952da01bc/e/a0f1b44723c7d0ef68900b58
https://cad.onshape.com/documents/ac36b4c9dcb9af7d189aae9b/w/bcab52b58daa7cc952da01bc/e/a0f1b44723c7d0ef68900b58
