selecting the face of a sketch
gerald_comeau
Member Posts: 61 ✭✭
I have come back to Learning OnShape after several months absence and am redoing some lessons for practice. I have run into problems with my sketching. The area inside enclosed sketch does not turn grey. I noticed this when I tried to use the extrude feature. A few days ago I made several extrusions and everything went fine then, but I ran into problems yesterday when I went to extrude in the Coffee Cup Exercise. Clicking in the sketch region does not activate "Faces and sketch reasons to revolve." The sketch seems to be OK except that it does not show the normal grey color within the area of the sketch. I made another simple sketch to verify, and again did not get the grey colour. I hope you can help me with the problem.
Cris_Bowers
Member Posts: 281 PRO
The region will turn grey when all points are joined. If any points are blue, it means they aren't joined. Can you share a screenshot of the sketch?
1 -
owen_sparks
Member, Developers Posts: 2,660 PRO
If you post a link to your doc we'd be happy to show you where the error is
Owen S.Business Systems and Configuration Controller
HWM-Water Ltd1 -
lana
Onshape Employees Posts: 757
@gerald_comeau
You'll find instructions on posting a link to your document here : https://forum.onshape.com/discussion/9107/forum-post-checklist#latest
1 -
Jake_Rosenfeld
Jake Rosenfeld - Modeling Team1
Can you post a link to the document here? We can check if there is some problem like Neil described or the sketch just isn't closed.
To actually open a support ticket, you need to press the "Report a bug" or "Contact Support" button from the "?" menu next to the share button. Just sharing the document with support does not alert us
On the drawing: I found the problem. The document was not closed. I had only a construction line on the vertical axis. Once I closed the document with a solid line, the grey region appeared and I was then able to successfully complete the Coffee Cup exercise.
I don't know where to find the "?" mark that you refer to. There is no "?" next to the share button I used. I'm referring to the share button towards the right hand side of the document home page. I do see a "?" with a drop down menu on top of the same page next to my picture.
I'm still trying to familiarize myself with the OnShape website and the possibilities available to me on OnShape. I have not asked for help except in this forum here, from Learning Center listed under Categories. I still have a lot to learn. I do not know the first thing about sharing one of my drawings. My occasional browsing for information on the topic of sharing documents have not yielded any guidance. Is there a course or a lesson that I can take?
That "?" dropdown menu next to your picture is what I was referring to
