Insert Part Studio with configuration into Assembly
I have a Part Studio with a configuration, now I want to insert this Part Studio into a Assembly complete with it's configuration.
Is there a quick way doing this?  Copying the configuration or something?
After inserting this Part Studio I want to add more part's from other Part Studio's and configure that.
Thanks in advance
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,979 image
    Hi @dick_van_der_vaart when you say “with its configuration” do you mean you want the assembly configuration to have the same entries? You have to create a configuration in the assembly then configure the configuration of the part(s). You can try to copy the table (3 dot menu in configuration tab and Ctrl+V) but it may not work because your inputs may not be the same.
  • dick_van_der_vaartdick_van_der_vaart Member Posts: 51 PRO
    @NeilCooke I tried the copy- paste, that doesn't work, and yes I want the assembly to have the same entries.
    I don't want to have to many features in one Part Studio, so I want make my other configurations in another Part Studio
