Send (Variable) Feature To Top / Folder
As we know, variables are within the feature list but I imagine that I am not alone in always wanting to have features at the top of the features list.
It would be EXTREMELY useful if you could "send feature to top (of features list)", or even "send feature to folder", where "folder" is an existing folder in the features list. Currently the only way is to drag-and-drop, which if you have hundreds of features is a real pain.
Alternatively you can "roll to feature" somewhere, create your variable, and then roll back to where you were, but this is quite inconvenient especially if you were already working in a rolled state since you have to remember that, or you have two windows open on the project one creating a sketch and one used for creating variables on the fly (until such time as we can create variables on the fly from within a sketch, having two windows is a quite workable solution) since if you roll in one window it also rolls in the other which is not desired.
every time you edit something on the tree it will need to regenerate everything below it.
so having all your vars on top means every edit will need to generate the part studio every time.
it is much more efficient to put the var immediately before it's first use in the tree.
then just type "var" in the search bar, it will then filter the whole tree and give you a nice easy list.
Was wondering about putting them in the correct place as John describes but driving them with configuration variables so you get a nice interface at the top. Dunno what that would do for performance?
O.S.
Could we have a "send to just before when this variable is referenced" feature?
to me that is a huge negative to config vars in lieu of tree vars.
