Mesh Point, Selection
I've imported a mesh and I want to select a point. Normally, I have no problems selecting the points I want, but sometimes there are points which just can't be selected
Like here, I'm able to select the upper point, but the lower point I'm not able to click on.
Any pointers as to what I can try or why it doesn't work?;)
Select other documentation:
https://cad.onshape.com/help/Content/select-other.htm
It looks like the other points I'm trying to select are "behind" a polygon, but shouldn't I be able to select the intersection between a line and a polygon?
https://drive.google.com/file/d/19TOtDg7vW638o95jE46KF3Yiwjqany2L/view?usp=sharing
