Choice for Horizontal or vertical orientation in the same Drawing template ???
francois_bouletfrancois_boulet Member Posts: 65 EDU
Is it possible to create a template where, in the same format, (Ex: A) while adding a new sheet you could choose from horizontal or vertical ?
In other words; How can you have in the same Drawing, horizontal and vertical sheets formats ?
La simplicité est la sophistication suprême.
Léonard de Vinci
    john_mcclaryjohn_mcclary Member, Developers Posts: 3,897 PRO
    Not today, you may need to create an improvement request
    Thank you,
    I'll do that ...
    Léonard de Vinci
    chrisjh777chrisjh777 Member Posts: 207 ✭✭✭✭
    @francois_boulet  Great question.  If you raise an IR, I will vote for it.
