Import and Rotation
famadorian
Member Posts: 390 ✭✭✭
I've imported this STL file, but somehow, it's oriented totally wrong.
Do I have to do all kinds of rotations on this to get it oriented correctly or can I just say that this first surface here is the right side and this other side is the top view, then it would do the rotations magically?;)
if you really want, you can use transform to re position your part. but the more I use Onshape, the less I find it matters.
In this image, the model is rotated about the blue axis, which according to the left is Z-axis
, but why? I've clearly stated that it should be rotated about the Y-axis?
The transform feature will aways rotate about the blue (Z) axis of the mate connector.
The "Rotate about Y" is part of the mate connector dialog, allowing you to change the mate connector from its original inference orientation by rotating it a certain number of degrees about its own y axis. If you play with the "rotation angle" field, you will see the mate connector rotate about its own y axis.
