For a sketch dimension that is configured, it is possible to change the table label text?
StephenG
Member Posts: 384 ✭✭✭
All of the sketch dimensions I add to a configuration table are given generic labels either "Distance", "Diameter", "Radius", or "Angle". Is there a way to change the label text to meaningful descriptive text?
Also, if I add a sketch linear dimension to a configuration List it is given the label "Length" instead of "Distance". Is there a good reason for the labeling difference?
Any typo while inserting a part into an assembly or drawing will create a unique part. Also makes it dificult to insert because you have to enter many variables each time, rather than just having ttem all under one drop down list.
Config vars have thier place, I just say keep them to a strict minimum.
In the mean time, I do believe if you mouse over, or click a value in the config table, the corrisponding dim will highlight. (Not sure if the sketch needs to be open, I'm not at a computer at the moment)
Sure, that would work. I thought you meant adding configuration variables.
IMHO it is a little overkill on variables when mouseover in the config will highlight your configured dim.
We just need the ability to label dims properly...
